Finally got my Stang's interior redone (both front bucket seats & both door panels) last week so now the interior looks as new as it can for a 15+yr old car.
Local upholsterer used a grey stitching in the outer seams of the seat covers that closely matches the trim color of the OEM Ford 08-09 Bullitt shifter boot's outer trim ring & did the same on both door panels.
Seat covers\door panel inserts are custom made from a much better\reinforced leather material than the OEM stuff which matches the OEM patterns & the door panels are guaranteed by upholsterer to not peel off again going forward.
This was 7 yrs in the making as the driver seat back's lower bolster was rubbed thru (had a hole worn into it.......fairly std for a daily driven car w\ 139,433 mi on her when I bought it) & the passenger seat back's lower bolster was starting to rub thru (black was rubbing off). Both door panels had started to peel off, but I made repairs to both door panel inserts (reglued) to keep them in check until now.
Found both front seat's side valance panel's front clip tabs had been broken & wouldn't stay attached to seat frame after I picked the car up (found both front sections of side valance panels had popped out when I got the car home), so I ordered OEM 05-14 GT charcoal black replacement side valance panels for both seats (didn't bother to take this up w\ the upholsterer due to how these side valance panels actually clip into the seat frame......pretty much guaranteed to break at least 1 of them when removing them to redo the covers......especially 15+yr old original ones......the plastic was crumbling between my fingers so I knew this was unavoidable.......) & replaced both side valance panels yesterday (pulled both bucket seats back out to do this......can't be done w\ seats still mounted in the car) to finish all this up.
Seats feel good & will hold me in them MUCH better now when pushing her thru cornering but also has raised my seating position about 1" higher which will take some time to get used to it........or the lower seat cushion to wear in, whichever comes 1st.
