the sandman
Is anyone that ran theses still around? I look at the list and my high 13 car should be low 12,s. Im just wondering how much truth is in the list as far as what it takes to get there. I see alot of 281,s stock cam, heads etc.
You could get low 12's with what I have plus more suspension upgrades, drag radials, and weight reduction. Cams & higher ratio axle gears will also get you closer, especially once you've performed the necessary traction upgrades that'll allow you a higher rpm launch without spinning the tires.Is anyone that ran theses still around? I look at the list and my high 13 car should be low 12,s. Im just wondering how much truth is in the list as far as what it takes to get there. I see alot of 281,s stock cam, heads etc.
Do you have a recent time slip to post? It might provide a clue as to what you're missing because, at least on paper, you should be running slightly better times than me.Hey Dino,I currently have the big JLTcai, ported TB, cmcv delete, cams, BBK Long tubes, ORX pipe, 2.5" to borlas, Aluminum DS, MGK short shifter, 4.10,s, skinnies and 275x60x15 MT drag radials on sve drags stars. I know the DR are too tall but I got them used. I don't want to drill holes in my new wheels to put the 26" slicks on so been looking for back wheels. I have rear lower control arms and wide band o2 coming. Don't have alot of time left before strip closes for season. Want to get some runs in soon. Car is 3600lbs with me and 1/4 tank, has 180k so engine is soft. I want car to run mid to low 12,s. It is my fun car street strip nice weather ride.
At the time of its launch 20 years ago, 300hp from 4.6L was pretty decent though, let's face it, Ford did leave a lot of power under the table. With just a decent tune alone, 325hp was possible and that would have handily beaten the 4.6 4V. I think I've got my car where it should have been from the outset with ~365hp & ~375lbft (crank) from simple bolt ons and a tune (stock HCI). That's 105hp & 73lbft more than a stock 4.6 2V!!Let's face it, the 3v 4.6 was a lousy platform.
Power/VE wise absolutely the 5.0 smashes the 4.6 3v it’s true, especially Gen 2,3s.Let's face it, the 3v 4.6 was a lousy platform. Once Ford came out with the 4v 5.0 in 2011, it only took about 3 years for all 3v support to evaporate. The Coyote was 100hp stronger right out of the gate, before any power adders. I spent a lot of money getting another 100hp out of my 3v.
Blasphemy! 3v rule!Let's face it, the 3v 4.6 was a lousy platform. Once Ford came out with the 4v 5.0 in 2011, it only took about 3 years for all 3v support to evaporate. The Coyote was 100hp stronger right out of the gate, before any power adders. I spent a lot of money getting another 100hp out of my 3v.
That's a decent 60' but I'd say you're probably upshifting too early. You can easily wind the engine up to 6500-6700rpm with your mods.I haven't had it to mid michigan motorplex in Stanton(bout ten miles) yet but on dragy I was running 14.0 at 99 to 100mph 13.9,s at 101 with 2.0 60ft if I remember correctly on street rubber.
skwerl said:Yup, the Coyote platform is 15 years old. I dare say in another 20 years people will still be building and racing Coyotes but nobody will be building and racing the 3v 4.6. Hell, almost nobody is racing the 3v now.
Nothing like some boost and E85 to level the playing field!
