All 24 rockers are in! It was tedious and fussy just as Whitman Ink (and others...) warned me. But I did it!
The finger on top of the valve thing us helpful for two reasons. One is the obvious one, the keepers don't move up and release the valve. Two, use that finger to tell you the valve is compressing. If the knob on the tool is turning but the valve isn’t moving, STOP! Back off and see where the tool is hung up. Knob turns and valve/spring go down is good. Knob turns and valve/spring not moving is bad.
Compress the valve spring as much as you can without increasing effort. That gives you the most room. And no tools! Do not put a wrench on that knob. If you do, now that you've read this, you deserve what happens next!
All the rockers go in from the valve side, not the adjuster side. Try to do the exhaust valves first as you go. They are harder to get in place as they come up from underneath, but without intake rockers next to them, it gives you some room for your fingers. The intakes are much easier since they drop in from above. My magnet worked pretty good at that. See the pic.
Also, if the rockers seem too tight going in, you can gently/slowly depress the plunger on the adjuster to get a little more room.
A little hint...do the very back drivers side intake rocker at the beginning. With the other two out of the way, its easier to get that one in place. Do the exhaust on that cylinder when it comes up as you do others for the same reason and then do the other intake rocker dead last because it will go in easier from above.
Magnet:
Last cylinder on drivers side:
