2006 GT - BBK Long Tubes + Catted X Resonance — Anyone Convert to H-Pipe or Add Resonators?
StockishS197
Houston
Sounds great! How do the Bullitts compare (sound and volume) to the stock mufflers?
I haven’t had a set of stock mufflers on any of my setups, so I can’t directly compare.
However of all my setups, they are one of the deepest and quietest setups I have had so far. I wouldn’t be surprised if they are as quiet if not slightly quieter than the stock manual GT mufflers. But the Bullitts definitely have more bass, so it could just be perceived as quieter. Ford had to make these meet the same noise emissions requirements as the stock mufflers, so it makes sense.
Ranking Ford/FRPP setups I’ve had, the FR500s being a 9/10 on loudness, the GTAs being a 7/10, the GTBs/Bullitt mufflers are probably a 4/10.
StockishS197
Houston
Nice sounds good! I ended up ordering Corsa sports because of your clip and endorsement plus several other clips I saw, the raw vicious v8 grunt combined with just enough rasp has grown on me. I’ll update on my thoughts.
I kept going back and forth on h vs x pipe. I think there’s the chance the corsas will be louder than I was hoping for but going to embrace it lol. They seem like the best combo for x pipe. I considered Borla touring to avoid the drone of s type. I think I’m going to have an exhaust shop fab an h pipe that I can run with the OEM mufflers that I can switch to when I want a more classic sound. Pretty impressed by the sound of JC SSP’s setup with BBK shorty, o/r H pipe and stock mufflers.
I would recommend keeping the X with the Sports first. It tames down the tone slightly until you are at WOT, then it screams. To me, the X compliments the Corsas better than the H, but it’s all subjective.
If you want loud but with a nice tone, the Corsas are it :)
MustangMark
Toronto
How loud were corsa sport out of 10 in this ranking?
MustangMark
Toronto
The Corsas are bar none the best axleback you can get on these cars, but they are also extremely expensive. Zero drone, probably quieter than stock inside the car. Their RSC technology is like magic.
Idle and normal driving the sports aren’t obnoxious at all, but when you get on it they are very loud (on the outside) with LTs and high flow cats. I was surprised how loud the sports were given they aren’t the loudest option. The cam chop is also very crisp with the Corsas.
My only gripe with the Corsas is the cold start bark - they are loud on cold starts. If my car was a daily and I had early cold starts, I would have to take them off otherwise I would annoy the neighbors.
I have had just about every exhaust combination between the two GTs I have owned (FR500s, FRPP GTAs, Borla S Types, Borla Tourings, Flowmaster Outlaws, Corsas, Vibrant mid mufflers, Macs), and the Corsas are the best all around. The very close second contender are the FR500s. Very on par with the Corsa sports. Third place are Borla S Types, but they drone badly.
Exhaust threads are always subjective so I would listen to a few of the options that are still available above and see what checks your boxes.
Btw how were the borla touring?
MustangMark
Toronto
I think the tourings are slightly louder than the GTBs but quieter than the old GTAs, so on my scale, probably a 5/10
Nice thanks for the feedback. I think h pipe with borla touring would be a nice moderate setup, but it’s so hard to know before you try.
The sharpness of the corsa’s started growing on me. My impression is that borla “smoothes” the sound, makes it deeper and cuts out a lot of high frequencies
StockishS197
Houston
Yep, Corsas have a crisp note. Think a high treble but moderate bass, whereas the Borlas have a low treble, but high bass.
I used JBA LT's...and high flow catted H. And FRS-500 mufflers on my 2010 auto with small roush M90 blower. Too loud, and had drone at 2krm. The fix was a pair of pypes 80 SS resonators..... installed just before the rear axle. That dropped the level and got rid of the drone.
That shoulda read, Pypes M80 resonators. They are made from 304 Stainless steel. Bought at AM...and were dirt cheap at the time, aprx $44.00 each.
StockishS197
Houston
You can also look at Vibrant 1794s mid mounted too. I also ran that setup for a bit with muffler deletes out back and it sounded good. It droned pretty bad, and the ground clearance sucked though
StockishS197
Houston
I ended up pulling the Bullitts off and putting the Corsas back on. Not sure if it was my particular used set, the the Bullitts did not flow much air, especially compared to the Corsas - felt a solid difference at idle airflow and with a leaf blower blown through both.
Exhaust seemed to also run a lot hotter with the Bullitts on and overall car felt restricted, so I swapped out the H and GTBs back to the X with Corsa’s.
Will also reiterate that an H Pipe is a LOT louder generally than the X, especially with the Corsas FWIW.
GlassTop09
Farmington, NM
That makes sense............most OEM designed mufflers that comply to OEM noise emissions levels will be a chambered design type & typically not a resonance\straight thru design thus will be a little restrictive flow-wise @ higher RPM's due to location at end of exhaust system (exhaust gasses will have cooled down thus gained density\mass & lost some flow velocity\energy by the time the gasses enter the muffler chambering creating excessive backpressure in exhaust system prior exiting......which will cause the exhaust temps to rise proportionally in the front end of exhaust due to retention time in pipe increasing from slowed flowing velocity that the O2 sensor heater circuits will pick up & report to ECU......).
Another reason why I stick to a mid-muffler\resonance\straight thru type exhaust system when performance is in the cards..............even though those Bullitt GTB's sound so good.........."cheap" HP\TQ comparative.
MustangMark
Toronto
Hey, thanks again for your help and I figured I would do a follow up. I ended up keeping the BBK long tube headers and BBK high flow catted x pipe and installed the corsa sport axle back.
Turned my Mustang into a fire breathing dragon lol. First of all, it is amazing how quiet it is cruising or just maintaining speed whether it be slow driving or on the highway. Zero drone maintaining speed on the highway. It’s like magic actually. Once you start to get into the throttle at all, let’s say in fifth gear at 60 mph you get a nice growl but nothing crazy.
Accelerating slowly, and I mean, slowly, is very tame. So they can be very civilized in a parking lot or drive-through if you want to.
Once you get 1/3 to 1/2 into the throttle, it becomes quite loud, but sounds really good.
Beyond 1/2 throttle and especially WOT, I don’t think it can be overstated how savage and loud these things are lol. Everyone I’ve taken for a drive has broken out into a fit of laughter and exhilaration haha.
Very loud at wide open throttle! At first, I thought it was way too much, but man it grows on you! Cold start is quite loud, warm start is not too crazy.
Attaching a clip of a cold start and a WOT pull with my buddy following behind me. Video just can’t capture it, but gives you a sense of the tone.
StockishS197
Houston
Sounds great!
The Corsa’s RSC technology is like magic. It’s basically just a really nice Helmholtz resonator in a T304 stainless body. There is zero muffler/packing in the Corsa’s, even the sports. They are a straight tube right through, just with a small resonance chamber.
Trust me when I say if you try and switch to an H pipe, it may be too loud, so stick with the X as it takes the edge off when at lower RPMs.
MustangMark
Toronto
Sounds great!
I might have an exhaust shop make an h pipe so I can have a second set of shoes for the car. I’m curious, how was the loudness of the borla S type with h pipe compared to the Corsa sport with x pipe?
StockishS197
Houston
S Types are a good but quieter compared to the Corsa Sports, but the S Types drone having had both.
The S Types sound great with an H or X pipe though.
