StangMahn
They call me...Big Dave
that looks fantastic! I really wanna build a track specific car one of these days
Marksti, is your cars weight with you in it?
More aero would be nice..your right
..the Roush track wing looks good also..but i have to save up for a 315 tire package.
No problem..one thing i learned is that whenever you change alot of stuff..is not to get to frustrated..as it takes a day or two at the track to work out the kinks.I know I'm a nobody, but I must say this is a beautiful car!! And thanks alot for taking the time to share all of the BS you learned and parts you used..Its nice to see another (few out there, $$$$) that shared their Grigg's trial stories..I may have some questions for you on PM if you don't mind some time.
Again, badass car.
Robert
Fix rear hood lift problem (now does it at 100 mph due to higher flow from grille)
Good points.. i was having understeer problems moreso in the slower turns (50-70mph)..then long sweeping ones..so i know the aero wasn't quite the whole problem..maybe part of it..but not all for sure.![]()
If you look at the FR500S grille, you can see where they have it blocked off roughly where the GT fogs would be. I think this is to combat hood lift and the understeer that is a byproduct of having a high pressure area under the hood. There's a guy on another forum with a Griggs equipped S197 who reported a significant handling improvement by installing a hood with massive heat extractors on it. Food for thought...
I will shortly vent the rear of the hood to help with the pressures.
If you're talking about removing the seal at the base of the windshield, don't do that..that's a high pressure area and you'll just let more air in. I took mine off, taped some strings to the back of the hood and what do ya know...even at 100+ they were getting blown under the cowl.
The torque arm plants the rear end IMHO vrs controlling the rear end movement with a LCA/UCA setup.How does the performance/feel of the torque arm compare to the upgraded UCA/LCA set up you had? I've looked into getting a Griggs SS setup on my car with a local installer. In their opinion the torque arm is the majority of the handling benefit of the package and they even suggested doing only the torque arm first and deciding on the coilovers later if I felt they were needed.
Thanks,
Blair
