graygt07
is anyone running around 550-575 rwhp on 93? i am debating on a new shortblock and cam and doing a smaller pully with #39 injectors and gt500 fuel pump and i want to make sure 93 will work.
im 565 right now with 9lbs boost and 39lb injectors. my.
your more than safe for what your asking for. im 565 right now with 9lbs boost and 39lb injectors. my new shortblock is going in soon and going up to 13lbs boost and 60lb injectors. with the gt500 fuel system im only at 40% duty cycle though with the 39lb injectors in currently.
That don't sound right.
For sure. I'm making 730rwhp on 6 lbs of boost and 87 octane fuel. But, I have to admit to using "104" octane booster to make it all happen!LOL, so wrong, it's amazing what kind of information people put out there.
are you running gt500 fuel pumps and harness?39's maxed out at 488 for me.
i have custom grind comp cams, bbk l/t, bbk x pipe, magnaflow magnapack catback, steeda cmdp, diablo mafia, frpp 4.10 gears, bbk twin 62 t/b, novi 2200, shaftmaster d/s, also have many other mods but this is pretty much how i made 565.That don't sound right.
a dyno jet has NOTHING to do with the fact that 39's will peak under 500. Ur starving your motor. Post the dyno sheet 1st and hope it has a A/F reading and SAE corrected.. Your talking about adding this and doing this, why not tell us what your build is and maybe, we can help you out more.
Just shocks me that i was making 560 with a built motor and 15lbs of boost with that fuel system as well. But u did it with 9........... i wanna see this.
just my 2cents
I believe you because i am doing it also with those same mods, 554rwhp sae. Paxton for the win i guess. But my injectors are maxed with this cooler weather so i upped the fuel pressure to compensate a little.There is some guys that are on here that are having a dyno day Mar. 13th I will attend to get on video of my 39lb injectors making 550rwhp on 93octane for the non-believersif your saying im wrong then you need to go join the 3vs197 fan club cuz i dont put shit out that i dont know. maybe its cuz i was on a dynojet or just have a great build but dont try and tell me wtf my shit does. i dont remember who else it was but he was running high numbers with his injectors running a low duty cycle also. im not trying to promote people doing it either as im going to bump up to the 60lb soon. im just saying what i got.
I believe you because i am doing it also with those same mods, 554rwhp sae. Paxton for the win i guess. But my injectors are maxed with this cooler weather so i upped the fuel pressure to compensate a little.There is some guys that are on here that are having a dyno day Mar. 13th I will attend to get on video of my 39lb injectors making 550rwhp on 93octane for the non-believers![]()
wow so i get gigged on here for saying i run 39lb injectors and run 565rwhp with a low duty cycle, geez. its not like im trying to tell everyone to go do it. im just saying if you got the right setup then it safe. whoever decided to throw in a negative for me on my rep standing is![]()
ya they did that to me also for this, so i had to add it to my sigwow so i get gigged on here for saying i run 39lb injectors and run 565rwhp with a low duty cycle, geez. its not like im trying to tell everyone to go do it. im just saying if you got the right setup then it safe. whoever decided to throw in a negative for me on my rep standing is![]()
