Twin Snail Build...
1BADHRSE
New York
Yea man... I just need to get a Autolite Plug gapper and see if that stops the spark from blowing out and breaking up...
bigmachano
Weapon IX
Wiesbaden, Germany
fucking amazing! i'm gonna be trying to keep that pulsing sound when i (eventually) get around to doing this. it seems like every time i ever hear about those garretts on a mustang, they just put out shit loads of torque!!! i can't wait to see where you end up! ...subscribing
I think BBR has the gapper tool on sale now.
what did you have the plugs gapped too?
1BADHRSE
New York
Couple videos of tunage...
It was a 4th gear just thought he shifted more at the time...
dlrs14
honolulu Hi
Congrats on the build! Your ride looks and sounds awesome, cant wait to see the #'s you get one the plugs are gapped
US-1
Banned
The ShadowLands
You'll run out of turbos at about 800-850 flywheel hp. Mine are 53mm and are good to about 900 flywheel hp. Deduct whatever amount you believe for driveline loss. My automatic soaks up 24%. We put down 477 hp and 541 tq on 8 psi and 10 degrees timing. The car ran 128 mph at 3820 lbs. Doing the math that equates to 626 flywheel hp. Remove the 24% and you're back at 475-477 hp at the tire.
Bottom line though: twins are bad sumbitches!
RetroGT2006
06 S197 Member
Florida
Very badass man!! Sounds great, hope the autolite gapper is what you need and it is all worked out soon. Keep us posted!
captainN8
LaPorte, TX
Torque for days!
US-1
Banned
The ShadowLands
That's the main advantage of turbos. People don't seem to understand how I can run 10's on only 8 psi. The problem is they are staring at boost and horsepower numbers. Torque is the key.
RetroGT2006
06 S197 Member
Florida
Yah 8lbs and doing 10s is insane..Very doable though! I plan to buy a Hellion turbo kit within the year and push around 8-9lbs. It will be the base 61mm with the ball bearing upgrade. Will that be too much for a stock motor?
Alrighty, sorry for the thread jack.
1BADHRSE
New York
Dam you also know how to hook like a monster... My suspension needs to get pieced together, I hate having this bull shit rearend slop...
How come you can run 8psi and I can only run 10-11? Are you externally wastegated sd?
1BADHRSE
New York
This is what I am running I don't think it's that much different....
US-1
Banned
The ShadowLands
Mine are externally wastegated. When I bottom the adjustment rod it gives 8 psi total. Probably because I have larger turbos. Bottoming the adjustment on yours yields 9-10 psi where mine is 8 psi.
