GrnBullitt08
Dale Jr
Very nice... Your car should be a monster once you get all the bugs worked out.
I think BBR has the gapper tool on sale now.
what did you have the plugs gapped too?
Awesome, car is gonna be sharp when its done. Sounds like he is barely even tapping into the power the car could make.
You'll run out of turbos at about 800-850 flywheel hp. Mine are 53mm and are good to about 900 flywheel hp. Deduct whatever amount you believe for driveline loss. My automatic soaks up 24%. We put down 477 hp and 541 tq on 8 psi and 10 degrees timing. The car ran 128 mph at 3820 lbs. Doing the math that equates to 626 flywheel hp. Remove the 24% and you're back at 475-477 hp at the tire.
Bottom line though: twins are bad sumbitches!
That's the main advantage of turbos. People don't seem to understand how I can run 10's on only 8 psi. The problem is they are staring at boost and horsepower numbers. Torque is the key.
Yah 8lbs and doing 10s is insane..Very doable though! I plan to buy a Hellion turbo kit within the year and push around 8-9lbs. It will be the base 61mm with the ball bearing upgrade. Will that be too much for a stock motor?
Alrighty, sorry for the thread jack.
