JeremyH
3V Fuel Guru
Mine has a stock transmission cooler, a/c, and intercooler. No cutting of anything.
what size intercooler do u have, i think 4.5 inch thick is the biggest i can get in there without hacking anything up
coated and wrapped?
Garrett 3 1/2" thick. Fits between the bumper supports and mounts off of them.
quit taking things so literaly one or the other most likely just ceramic vht paint and wrap the down and up pipes
Yeah i have right now i want to get it on and working then go back and paint, coat, wrap, make it pretty lol[
The last time I checked, also would mean both; or was it you that did not understand bobby1110's post?
Most importantly... you said:
quit... make it pretty lol/QUOTE]
'lightblade', ...![]()
yes i meant do both and the vht stuff will come off very fast. it needs to be either ceramic or high temp powder coating which is what i did to mine. pm me and i can give you more info if you are interested.
Sounds like a fun project.
yea those things are a bitch to get in and out. i had that same set up before i went to the triple set up so i have had the pumps in and out of the car several times. and yes it is a bitch every time. it is like the tank needs to be slid back 3" or so to line up with the hole better.
YOu can buy it, go to tousley ford and view the tank assembly and it breaks it down. About $6 for the ring
The FPDM should not have a problem running both of those correct? (will the FPDM wiring upgrade help that?)
