TPMS sensors
stang910
Jacksonville, NC
Does anybody know if the 2011 uses the same style sensor as 05-09. I'm getting a 5.0 soon and need to know if my current tpms sensor will work with the new car since I'm going to put my aftermarket wheels on the 5.0.
dagamore
Poor Driver mod
K-town Germany
i would think that they use the newer '10 setup, i.e. the one under the fill valve, not the band strap on style from 05-09. just my 2 cents.
2011CS
2011 California Special
valve style yes, I have 4 in my garage awaiting installation.
They cost about $30 each U.S
ocpony
Where did you get them for that price? My dealer says they list for $71 and even with my discount they are over $50 a piece.
MELLOWYELLOW06
Los Angeles
I heard somewhere that you can take a sensor and place it in a pvc pipe and give it pressure and throw it in the trunk and you can bypass problem. Anyone else heard this and has more info or is it all bs?
19COBRA93
Ford Racing
Clinton, Ut
You'd have to do it to 4 sensors, and you'd have to make sure the pressures were all the same and that they never leaked. Sounds like a PIA.
As for the sensors, from production date 2-26-09 all mustangs use the valve stem type sensor through the '11 model year. Prior to that production date they were band type sensors.
ocpony
THe one on my car is Part number 9L3Z 1A189A. I can't find it on websites to match that number so I don't know if there will be an issue or not. What does the car do without the signal from the sensors? I am mounting the bogarts to car on Friday. What have the other racers with big and littles been doing?
19COBRA93
Ford Racing
Clinton, Ut
9L3Z-1A189-A (Motorcraft# TPMS-12) Is the newer valve stem sensor. Without the sensors, the only thing the car will do is turn on the tire warning light in the dash. That's it.
19COBRA93
Ford Racing
Clinton, Ut
So why are you guys replacing these sensors?
You can just remove them from your stock wheels/tires and install them in your new wheels.
2011CS
I wanted to keep them in my factory wheels, so I could put them back on as is anytime.
I'm still hoping someone comes out with a proper 19 DR someday, then I can sell my aftermarket wheels.
