Liftedbronco
Shredder
ill make the downs meet. come hell or high water. im starting tonite. gotta clean the garage and buy some shelving and some portable lights. aaand a engine hoist soon.
heres a teaser.
Does anyone object to me lifting a motor from these pulley bosses? Is there a better way that I should use when im pulling the longblock outta the car?
well when im pulling the other one out, itll still have the heads on it. is there a better bolting point for the chains/
Exactly. I'd more prefer using the top two alternator mounting points.Heres my opinion...I would worry about damaging the gasket surface where the chain is hitting. @ least get some large rubber hose to keep the chain away from scratching your gasket surface. Its aluminum so it will get damaged easily with a steel chain.
Rick
