Matt D
S197 Pilot
oh that's differn't.... dam moroso pan isn't coming with
Wait til you see the oil pan gasket for these... Built in windage tray.
I won't be using the power steering pump or ac condesor ither .... Mine should make some killer power if I go through with it all... Comp just released their first set of cams too..
Realistic I can see these motors making 500+ at the tire on a stock bottom end when the cams come into effect... and make power up to 8000. This is the make or break deal in the NA game and if I want to go correct I feel the 5.0 heads is the key.
Very LS1 of them, don't you think?
If only they had copied a larger bore spacing while they were at it....Did I miss the news about aftermarket cams?
Blasphemy!If only they had copied a larger bore spacing while they were at it....
They did. It is the 6.2 engine.![]()
with 2 valve heads -_-
They should of made a set of 4 valve heads fit that motor and went for big power
Got an LSX sitting in my way screaming "454 small block," don't make me do it!They did. It is the 6.2 engine.![]()
What do you think this is, Burger King? It's not always our way
Hurry up and stuff one in your car so I can follow suitGot an LSX sitting in my way screaming "454 small block," don't make me do it!
Ok, that's been out for a while. There was even something on Comp's FB page, then it was removed that same day or the next day.
There's still no info on their website about the cams
Unless said 6.2 engine is all aluminum.....
And if you check the blocks closely you'll see some interesting provisions for different cylinder heads.Got me all perked up now...I know where there are a few of them.....and I'm trying like hell to get my greedy little claws on 'em!And if you check the blocks closely you'll see some interesting provisions for different cylinder heads.
