All Motor Chat - High Gearing, Light weight, Revin to the moon-
US-1
Banned
The ShadowLands
And then there's things like external wet sump systems or dry sump systems.....vacuum pumps.....coated pans/windage trays......hand cut scrapers....oil limiters........
:evillaugh:
Matt D
S197 Pilot
Toronto,Canada
Dry sump is a no go. I was thinking vacuum pump but is my little motor really going to gain from it? I have yet to see a modular pull a set up off...
marcspaz
~Resigned~
I don't know how far you want to take this... but I have friends who are pro racers on the road course tracks. They go as far as doing a heat treatment and major polish job on all of the trans gears and R&P to reduce surface friction. These guys swear buy it. I have to think it would help drag cars too.
Matt D
S197 Pilot
Toronto,Canada
I was thinking of lightning & heat treating my Rear end gears but nothing inside the trans..
I will be going to a lighter flywheel aswell.. Wan't to get this motor to pull hard very quickly lol
Matt D
S197 Pilot
Toronto,Canada
YES! found the bracket for the pump, didn't think they would make one :)
[FONT=Arial,Helvetica][SIZE=-2]63921 [/SIZE][/FONT][FONT=Arial,Helvetica][SIZE=-2]Moroso "Enhanced Design" Vacuum Pump. Mounts to Ford 4.6/5.4L Modular Motors to timing cover on the lower drivers side[/SIZE][/FONT]
Matt D
S197 Pilot
Toronto,Canada
4 Vane pump seems to be the most efficent and lightest they offer
[FONT=Arial,Helvetica][SIZE=-2]22642 [/SIZE][/FONT][FONT=Arial,Helvetica][SIZE=-2]Enhanced Design 4-Vane Racing Vacuum Pump, -12AN Fitting, Hard Anodized Finish[/SIZE][/FONT]
Cog pulley for pump #6488
Germeezy3
At what point does the valvetrain become a limitation? And what are the guys pushing the limits for N/A 3V running for heads and cams? Livernois Stage 3's with Comp Cam XFI's or custom ground cams?
GrnBullitt08
Dale Jr
Northwest Indiana
Nice finds, this will all be very useful information for me during the next year. I just grabbed a new shifter finally so I could ditch the stocker. I have a long road before I catch up with you. If I ever do... Lol
Matt D
S197 Pilot
Toronto,Canada
I have the 127500 Xfi's , Custom grind is the way to go but big $$ depnding on the set up.
The 127600's and the stg 3 livernois or almost any hogged out head would be a great combo for off the shelf parts
Matt D
S197 Pilot
Toronto,Canada
I still have the stocker in mine :roflmao:
GrnBullitt08
Dale Jr
Northwest Indiana
I don't like the height of the stocker, sits to low. The Hurst Comp should place the shifter right where I want it. And that vaccum pump looks like it sits right where the power steering pump sits... Hmmm
US-1
Banned
The ShadowLands
Depends on the ring pack you have in the engine.
It works in drag race setups as well.
When the lift of the cam pushes the retainer down onto the guide boss. :roflmao: Then we get to playing with longer valves, taller springs, and reduced base circle cams.
Price on custom grinds is the same as shelf cams, kid.
