GrnBullitt08
Dale Jr
Personally....I like four valve heads. Just depends on which heads you use. The GT500/Ford GT heads are the best of the best. The 03/04 Cobra heads are next and are slightly better than the 3V heads if they're worked right.
For high rpm N/A use I wouldn't suggest using the stroker though. Rod/stroke ratio doesn't favor it. You'll make more power with the big bore and stock stroke & rod length. I also would not go to a 6" connecting rod with the stock stroke due to side loading the piston.
Thanks SD, I will keep the 4V heads on my list, if I can find a set if 05-09 Gt500 heads I will def go that route. I'll have to look into a new intake as well if I switch heads. I don't think the FRPP is gonna fit....
