Wicked97
What ring and pinion is that? Did you get it refinished? My 4.56 has a dull grey color to it.
Its a Polished 4.56 Motive AX (light weight)
It was in a camaro with 4.10s and 28" tall tires.well you will have to expect that. its got 1.1 liters on ya with better head flow. im assuming a early cts-v and not a c5 z...
I put in the hurst short throw. I like the shift but the linkage still binds up.Good to know...I have a Hurst Comp Shifter going into the car, Im hoping that helps a little.
Oh I see.....I have a motive 4.56 in mine. Is it better to go with the polished (lightweight) setup? Are they as durable?
The polished gears are worth something i cant really tell you how much, Just becasue its so hard to test.
as far as the light weight AX gears go we run those in alot of our race cars. low 1.3 60 foot times no major issues. I mean you can break anything at any given time.
sweet the number i was looking forYou are number 7 sir![]()
This is how mine looked after I did them, Motive 3.90's:
I don't recommend the average Joe do this though, you do add a decent bit of noise to the car at highway speeds.
Sounds like a centri is in the diff. LOL
Yes, the higher gears make some noise....my 4.56s were making a ton of noise and after pulling that cover back off tonight to recheck the backlashing we found that my spider gears in the differential were loose and looks like the diff needs to be replaced.
It's not the higher gear, it's the polish in my case. The faster the gear turns the faster it's shedding oil. My theory is this is creating air pockets between the ring and pinion which causes a "hum" that increases pitch as you increase speed after around 70.
I've never ridden in a centri car, but I can imagine! Any gear set I've done this to.....
Yeah I agree with that statement...I think I may look into a polished set of gears like yours. How much did they set ya back and where did you get them from?
If I'm not mistaken Roush sells some, or you could send a set to REM.
If you have to ask...you can't afford it.![]()
Had a guy at a show once ask me if he could do that to his crank on his own with some sandpaper and steel wool. I told him he'd spend less to let me do it
I can't tell you what it would cost but I would guess $100+
