KrisR
Thought the completed product deserved its own thread.
Car is a 2005 Mustang GT. Forged 8.5:1 compression shortblock. Stock H/C/I/TB/exhaust manifolds/axleback. Literally a stock 2005 GT with just lower compression and forged internals.
On3 Performance turbo kit with MP T-70 upgrade. PMAS HPX meter.
Only made a little under 13psi on spring pressure on the dyno, which was around 500/510 at the wheels with 20 degrees of timing. We added about 4psi boost which ended up at around 17psi and it ended up making 551/558 SAE corrected (like 574/581 uncorrected) with 18 degrees of timing in it.
16psi pull (you'll notice fuel is a bit lean. Added a little fuel after this pull but power stayed the same):
16psi vs my older 14psi blower pull:
16psi vid:
http://s128.photobucket.com/albums/p187/rehn1kri/05%20Mustang/?action=view¤t=DSCN6165.mp4
16psi vid:
