tmcolegr
It's All About the Build
The Afco is not just dual pass but dual core also correct???. I did this same change from the Fluidyne that came with the Whipple which measure 10"x1.5"x21.1875" for a surface area of +/- 211.87". The Afco measured in a little shorter at 9"x2.5"x22.5" for a surface area of 202.85" obviously a little smaller. If yours is a dual core unit shouldn't the second row count as exposed surface area? So then why divide by 2? Why not multiple by 2 since you now, in essence, have the same surface area making a second pass for a total of 45" (22.5"x2) of exposure. Then this would come down to some physics forumal way past my education levels to determine how fast heat is transfered out of your medium (ie water, raditor fluid, etc) X amount of total time exposed/temperurate of outside air or some kind of thing? Not to mention the tanks on the Afco are larger which should still count but at a fractional level compared to the cores and fins.
Perhaps these next 2 pics will answer your question. Both the inlet and outlet connections on the Afco H/E are on the same side. Coolant enters through one end of the H/E and passes all the way to the other end of the H/E, turns the opposite direction and flows back toward the other end of the H/E. In this first picture you can clearly see the tank on the inlet side of the H/E s divided in half - notice the weld line
Now if you look at the other end of the H/E the coolant simply turns around and goes though the other half of the H/E. Notice the lack of a weld line - one common tank
Based on this, the H/E actually has 2 separate cores connected by a common tank.
