JeremyH
3V Fuel Guru
Now im confused. lol
What is a hyd bearing spacer and where would that go?
Gotcha, im gonna use the new oem slave again and use the shim from jegs and see how that does.
whats crazy is that there has been 100 of these conversions with zero issues......i thought this was a piece of cake straight forward swap.......
Jermey, I need a shim for sure with mine. You can tell when shifting quick that the clutch isn't fully releasing. The car will also lundge forward slightly when trying to put into gear with brakes released. Same crap the 3650 with rst did. Looks like Mcleod would tell their customers they need a shim when using their setup. 2 clutchs, 2 different transmissions 2 slaves same 8 bolt flywheel. Sooo. It has to be just the Mcleod brand. Oh and side note here. My flywheel looks brand new so I know there isn't an issue there. Zero wear.
