Art has very solid points. Without a tire or a gear your not going anywhere, the 127500 are pretty wild cams and need the rpm
moving to 4.30s from 4.10s made a big difference for me, and I'm curious about how it would feel with the 4.56s...
Yep, 5sp. The 4.10s were a GREAT street gear, but the 4.30s really helped out at the track. I have those 127500 cams too, which require limiters (which I have) or lockouts. I had 127300 cams for a while with those 4.10s, which made for that great street combo. Just enough low end torque, and still made power at high rpm. But the 127500 cam is really what's needed at the track. With 4.30 gears, that cam is still streetable although it's starting to get quirky at low rpm around town driving. But it really flies at the track, and I know I'm an easy 11 seconds once I get some cool fall air around here...
Nice Launch Matt xDThe photographer hasn't send me my pics yet... But he updated his site lol
Art , last one check this one
http://www.dragnden.com/Other/July-OSCA-Race-3-Sunday/13002572_sf7si#945988842_SAjYW
so for being street friendly would 4.10's be ok or are 4.30's pretty much a must have?
Last year when I ran the 26" tire with the 4.30's It worked great street and strip. Realistcly 4.10s are a great street gear for your combo / with the spray. But I couldn't help to think that you will upgrade them anyway a few months later, save the trouble and go straight to 4.30's and you will have a nasty na car. Im sure everyone na will vouch for that lol
Other than the in town slow speed stuff in 1st gear, the 4.30s are just fine. Frankly I'm sorry I stuck with 4.10s for 3 years.
yup seems that way. it's def nice to be able to find someone who has experienced a set up similar to want you want to run so you get what you're looking for.We have enough of us Na guys you can get opinions from and if you look at all the set up's you will see what works. 11.7-12.4's we pretty have much tried every part in the book for the best set up
28" tire with a 4.56 gear I feel is the ultimate combo for the all motor set up. When I ran the 4.56 and 27" et streets I just broke into the 11's and was spinning bad even launching at 5400 rpms and still hitting the 12.0's. Best thing I ever did was buy the 28" 10.5" My car leaves perfect every time now, it might spin one rotating but then still grab like a baer. I run 11's every pass now Those were the best invesment I did on this hole set up
Art you running a 28" now to?
I'm running 11.8's at will now with the 27's.
Nice Launch Matt xD
Put one more turn on the right rear heim joint Matt (pre load).
Nice pic.
