2013 GT500 cast aluminum oil pan 8.5 quart
BadPiggy
Hooligan Ahole
Knoxville, TN
That I cannot answer. I'm building a fresh motor.
Never removed a bolt from the oil pan on this car.
Perhaps BruceH or skwerl could answer that.
Sorry, should have explained myself better, I meant to ask if they were longer than the stock ones (as I think is thicker than the cast one)
crownaviation
http://www.tudyno.com/
Broke dafuk down
I am no structural engineer and I would be happy with this idea for the majority of builds out there... but, I am wondering if the stock metal windage tray offered any structural integrity to the block. This is my thought for north of 800rwhp applications where severe flex is a concern. I love this idea and am pulling my motor today for a few upgrades but have reservations about using this on my new build
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
Considering I can bend it by hand, I doubt it has too much of an effect.
Especially considering how much beefier the big GT500 pan is than the stock pan.
19COBRA93
Ford Racing
Clinton, Ut
Yeah, the mains aren't moving around any on these motors, so the metal windage tray provides no extra needed strength. If this were a 2 bolt pushrod 302, then I'd say maybe. And even then it would be a weak maybe. It's just a stamped piece with no "strength" built into it (ribs, gussets, etc).
AutoXRacer
Florida
Damn, I wasn't planning on this mod...but the more I read about it, the more I think why the hell not. sigh
Does anything have to be done with the oil pickup tube?
I guess since its the same depth as the OEM pan, there are no tolerance issues (pickup screen to bottom of pan)?
AutoXRacer
Florida
Cool thanks!!
Is the pickup tube bolt-on? Or does it require grinding the attachment boss...?
Another question that hasn't been asked... Is that plastic windage tray perform better than the metal one? Seems like everyone is focusing on the oil pan...but what about the design (performance) and placement of the windage tray?
sportinawoody
Piedmont area , N.C.
should just bolt on but i won't know until later next week when i button up my bottom end. maybe bruceh or sqwerl will know since they're already running this pan
hamish
B.C.
I might need some r&d on this as I'd like to increase my capacity.
But my stock windage tray needed to be modified for my 3.8" stroke crank.
I take it you can't use the stock windage tray with this?
19COBRA93
Ford Racing
Clinton, Ut
The way I see it is, it's the latest design from Ford. I don't see them going backwards in performance/function, so I trust Ford uses it because it's better.
19COBRA93
Ford Racing
Clinton, Ut
No, this is a windage tray. So pick one, not both.
AutoXRacer
Florida
Gerald,
It's bolted on. Use the spacer and nut already being used.
Has it been measured, checked, and double checked...?
I really don't want to find out that my pickup tube is out of tolerance and on a fast corner pulling 1G my oil pressure drops to 0!!!!
:mad2:
lol
W3bb3r04
Slow 3v Member
Clinton, TN
You have to trim the windage tray a little where the front studs come up I believe.
