Cal26Stang
Did he ever post videos of his car running? This was the most painstaking attention to detail I've seen on a forum, and the documentation was so in depth. very impressive
I did that last time and it leaked that is why I am looking at the product above. Have you ever used it?use rtv silicone not that stuff
Is this sealant supposed to remain soft?
Any of it exposed to air will stay soft, so it normal to be soft on the outer edges.
Thanks.Really, what are you basing that statement on?
I called Permatex's Tech Support and gave them the OEM part# and this is exactly what they suggested using.
http://www.permatex.com/products/Au..._makers/Permatex_Anaerobic_Gasket_Maker_b.htm
Be sure to read the Tech Data Sheet
Used this product on several rear main seal plates on 4.6L 3Vs and never had any leaks
