Obviously you are referring to a mod which I am not aware of for the 4.6L 3V. The only cooling mod I have found is for the 4.6L 4V.
+1, I only knew about the 4v heads having that... :/
Seeing how close the head is to the firewall....what are you going to do when/if the fitting begins to leak? Race car is one thing but a daily driver?
Are there any other negatives I should be aware of? It seems the easiest way to make it accessible to repair would be to weld a female bung to the back of the block on both sides, then if the fitting leaks all be it a PITA to make it work you could replace the fitting without pulling the motor no? You would know better than I am so that's a serious question.Obviously you are referring to a mod which I am not aware of for the 4.6L 3V. The only cooling mod I have found is for the 4.6L 4V.
Hey , I know that guy !I wasn't aware this was a daily driver, my apologiesAre there any other negatives I should be aware of? It seems the easiest way to make it accessible to repair would be to weld a female bung to the back of the block on both sides, then if the fitting leaks all be it a PITA to make it work you could replace the fitting without pulling the motor no? You would know better than I am so that's a serious question.
http://s197forum.com/forum/showpost.php?p=393245&postcount=522
Took me forever to find that post, pictures do a good job of explaining it.
So by tapping those lines, what are you accomplishing? I'm confused.Hey , I know that guy !
That's why I had the female welded in instead of trying the bolt in method Ive seen on the 4v stuff (the idea came from a JPC thread I seen on here). It shouldn't have anymore chance to leak then any other AN fitting would . If I did it again though I would just weld a male in there and not have the two piece setup. I still may do it before it goes back in . I am thinking of getting two bare alum. male 90s and setting them at the angle I want and welding it all up.First time I've seen that on a 3V. Thanks for posting. However, I am running a Saleen S/C and I don't believe I have enough available real estate for those lines. Could be wrong though.
It could be a bitch to fix if it leaks.
By any chance was it on the LH? (the last two comp grinds I've installed both had the same problem)
damn man, you bought every last specialty tool didn't you! I should have waited on my build to borrow more tools from you..![]()
Sure did!! I have almost every 4.6L 3V specialty tool referenced in the OEM manual and then some.
