CPRsm
- Joined
- Jul 11, 2011
- Posts
- 3,043
- Reaction score
- 1
What rpm does the converter normally footbrake to?
How are you guys disabling the DTC's for the transbrake on the '13+ cars, I'm being told the switches arent in the SCT software for those PCM codes(WYN3, DWP3, XYH1, YGK1)
Mine is WYN3 also and I have been told by 2 different very reputable tuners that the switches for P0962 and P0748 are not in the calibration. Driving me nuts.I have the WYN3 PCM and Lund was able to do mine and I am tuned thru a xcal3
3,800 rpm it starts pushing thru the brakes
On t-brake I have held it at 4,800 several times with zero issues and I am making over 470rwhp n/a
Sent from my iPhone 5S
Don't use the 3 relay version. As I've said since the beginning, you don't need to raise the line pressure.
I was planning on using the 2 relay version and after talking to someone who has done it they said they did not disable the DTC's and got no codes. I was unaware you did not need to adjust the tune with the 2 relay version.
It's been posted before. You will need to set engine stall speed higher in the tune so the car doesn't go into failsafe mode with either version of the tbrake. As mentioned earlier, if you have a converter and accompanying tune it shouldn't be an issue.
yeah I see it now in post #4 , having revisited this thread after some months I should have gone back and reread from the beginning...thx
Im bogging off the tbrake anyone think that the stock converter flash has anything to do with it? 11.1@131 1.83 60'. Converter is next on my list. I think I launched at 2500ish
Couldn't embed for some reason http://youtu.be/NXgwfIyWDQE
stock converter and footbraking I get to 1500 rpm then it pushes the tires, need to change my 1.8 1.9 60 foot asap.
