BMR Watts Link - Teaser
BMR Tech
Traction Vendor
Tampa, FL
We do have instructions available for those who have ordered the Watts link already. You can feel free to shoot me an email, [email protected] and I can get a set out if people need them. They will be posted on our website when we get the product page done, which should be done by Monday/Tuesday.
As far as starting points for the RC, I would recommend setting it up so that the arms are parallel to the ground, and the mounting points will depend on which springs you have on your car.
Kelly, though I bought a Fays 2 waiting for your watts link, I am never the less interested in purchasing yours! How do I go about it?
You can give us a call and place an order over the phone, or just wait for the product to go live on the site and place an order there.
Got mine today!! Thanks Kelly I'll post some pictures once it is installed.
:thumb:
Kelly should be back on Tuesday if you guys have any questions for him!
BMR Tech
Traction Vendor
Tampa, FL
Here's our rod end/rod end
and the poly/rod end version
TGR96
el blanco nino
Huntsville, AL
I'm late to the party... But will this work with rear ends that have an axle girdle (beefier axle cover)? Like the FRPP low profile, standard, etc.
I'd like to know this as well. I just put a Boss diff cover on my car. Will the BMR WL clear it?
And $550 is a smoking deal for a new WL :thumb2:
BMR Tech
Traction Vendor
Tampa, FL
It sure will! Here is a pic of our rod end/rod end with the finned cover installed. We haven't tested it with any other aftermarket covers though, just the OEM finned cover.
popeye
Never mind, I see it
Sent from my SAMSUNG-SM-G870A using Tapatalk
cbass
Rochester, NY
How well do the rod ends hold up to winter abuse? I have a (cheap) phb now, and after one winter, the rod ends are shot.
BMR Tech
Traction Vendor
Tampa, FL
You should be able to get about a year or two out of them before they need to be replaced. There are rubber boots that you can buy to cover them up. It will help to keep the grit and dirt out of them and should prolong the life.
http://www.summitracing.com/parts/sit-rers3
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Kelly told me to put motorcycle chain lube on my rod ends, and it's worked quite well for the past year. However, my car is not driven in the salt.
jraskell
My own personal experience with New England winters (which involve regularly driving through some pretty harsh salt/slush/road grime), No variant of rod end, roto-joint, del-sphere, etc, will hold up to any sort of significant winter abuse.
I daily drive my car year round, it's my only vehicle. Come Nov/Dec, I just slap winter tires on, a couple 75lb bags of sand in the trunk, and keep on driving. Years ago I went full rod-end suspension. The Rod-ends never made it through a full winter, none of them (and I tried the Seals it boots as well). For a couple years I replaced them each spring, not exactly a quick and easy job. I then gave roto-joints a try. They still needed to be maintained each spring, which involved seriously loosening them up, cleaning them out, and re-tightening them. Still not exactly a quick and easy job. After a few years of that I just gave up and went poly.
If your vehicle is going to see any sort of significant dirty winter usage, my recommendation is to forget any sort of rod end. If your winters are fairly mild, or the car will only see occasional use during the winter, then it may be worth trying out.
Wes06
Bout damn time they got listed. Lol
Also where's your fancy BMR tag
cbass
Rochester, NY
Well is there a poly end that one could purchase? I'd like to not have to break shit down every spring.
