Manny
I could not locate the specs for the DR S/C camshafts in the database at COMP CAM, but got these specs from their customer service dept:
Intake
DESIGN ID: 19207 ID NUMBER: 19207
LOBE LIFT: .450
DURATION AT 50: 234.00 AT 200: 179.00 OFFSET AT 50: .4
CHECK HEIGHT: .006
DURATION AT CK HEIGHT: 273.00
ADVERTISED DURATION: 273 OFFSET: 2.6
VALVE LASH:
INTAKE LIFT AT 106: .103 AT 110: .081
EXHAUST LIFT AT 106: .105 AT 110: .084
Exhaust
DESIGN ID: 19216 ID NUMBER: 19216
LOBE LIFT: .450
DURATION AT 50: 239.00 AT 200: 180.00 OFFSET AT 50: .4
CHECK HEIGHT: .006
DURATION AT CK HEIGHT: 282.00
ADVERTISED DURATION: 282 OFFSET: 3.2
VALVE LASH:
INTAKE LIFT AT 106: .112 AT 110: .092
EXHAUST LIFT AT 106: .114 AT 110: .093
I found these specs on another forum for the stock camshafts (can someone verify?):
Theoretical valve lift @ 0 lash intake 11.166 mm (0.439 in)
Theoretical valve lift @ 0 lash exhaust 11.066 mm (0.436 in)
Lobe lift intake 5.520 mm (0.217 in)
Lobe lift exhaust 5.506 mm (0.217 in)
Allowable lobe lift loss 0.00127 mm (0.005 in)
Journal diameter 28.607-28.633 mm (1.126-1.127 in)
Camshaft journal bore inside diameter 28.657-28.682 mm (1.128-1.129 in)
Camshaft journal-to-bearing clearance 0.024-0.075 mm (0.001-0.003 in)
Runout 0.03 mm (0.001 in)
End play 0.0050-0.250 mm (0.0002-0.009 in)
Here is a good article on camshafts:
http://www.mustang50magazine.com/techarticles/m5lp_0807_ford_mustang_camshaft_selection/index.html
I'll be installing them next week.
Intake
LOBE LIFT: .450
CHECK HEIGHT: .006
VALVE LASH:
Exhaust
LOBE LIFT: .450
CHECK HEIGHT: .006
VALVE LASH:
