FAST3V
Resident Fuktard
LSA is lobe sep I believe. So yes, 115....those might work fairly well for you Mike.
I got mine from Comp and they are basically the 127500 but on 115° lobe separation. l like them a lot. I would give the guys at Bullet a call and they will go through your whole combination and recommend a grind for you. They don't cost any more then the Comps, from what I hear.
I should have worded it a bit better, overlap was what I should have said. If you have excessive overlap (can come from either a tight LSA or duration) you basically pressurize the exhaust from your boost going out the exhaust valve. This isn't much of a problem with headers and a decent exhaust system on a blower motor but with a turbo you are already dealing with removing the exhaust from a boosted motor and then have to spin a turbine which is a lot more restrictive than a set of headers and a crossover pipe that can scavenge the gasses for you.Can someone explain how backpressure can be affected by the duration changes? Is it because the exhaust is open longer, to make the engine breathe better under other f/i operations, but with turbo, you want a shorter duration to get better spooling?
If going back to stock cams, would springs need to be changed as well? What about VCT?
(yeah the "shop" doing the install has no "experience with spec'ing out cams"..only putting them in.)
Leo,Tiger, I do all of my own work.
Thanks guys.
