I'm looking for some dimensions on the EPAS unit. I'm looking for:
-the distance from the edge of the boot to the edge of the opposite side boot
-the distance from the end of the tie rod to the oppsite side tie rod
Thank you in advance! I'm trying to see if this will work on a swap I'm working on
Ok I got it. 38" from boot clamps and seeing that mine is installed I estimated the rod lengths at 54". These are close but might be a +/- a little. I hope this helps.
