Car wont idle unless clutch is in!
palanza7
Okay first of several new build issues is proving to be the biggest head scratcher.
In the tuning process. Car just wont idle, surges up and down - until I push the clutch to the floor. While I hold it there car will idle just fine.
So what gives? Obviously transmission in neutral. I mean the car is on jack stands.
I did a full wire tuck but my connections must be good regarding the clutch otherwise the car wouldn't start lol
ANY ideas?
rocky61201
SoCal
I had my car running while on jackstands once because I was searching for driveline noise. It ran the same way.
Put your car back on the ground and see if that solves your problem.
palanza7
No idea why but once i put the drive shaft and calipers back on the things idling okay.. Lol wow
