Chasing Superchager Belt Issues/Engine Knock/Clutch problems
AutoXRacer
Florida
Crown, do they have this for flange setup (bolt and nut)?
My header/collector to mid-pipe bolts and nuts keep loosening; I even have double nuts and lock tight.
GT500KR
Quad Cities, IA
Well I'd like long tubes. .. but I like to keep working on my car as little of a pain in the ass as possible. Plus I still have that plan later to go turbo with a fender dump. So this way I don't have to buy a grand or so in long tubes and then take a hit on them later to sell them.
Sent from my SM-N900V using Tapatalk
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
I have an extra set of stage 8 locking header bolts if you're interested. $40 new, I'll do $30 shipped.
def67
Me^ Stuff I say>
Alberta, Canada
I'm very new here, but wanted to point out that this thread and the 08 rousch rebuild thread keep me coming back every day! Thanks for all the awesome info you two!
GT500KR
Quad Cities, IA
Thanks for enjoying my misery :/
Haha hope others can learn from me when you aren't told about all the oh by the ways. And little stupid Fucking mod motor bullshit
Valves are bent
Going for another ride. This time in the trusty dodge/turbo dakota
AutoXRacer
Florida
Nice motor!!!!
Who painted your motor? I like that idea of just painting the front cover as that cover is casted nasty.
crownaviation
http://www.tudyno.com/
Broke dafuk down
Valves are bent
Rear engine Dodge Dakota? Motor is installed backwards and a cheezy motor mount but atleast it is Ford..
Department Of Boost
Alpha Geek
If it makes you feel any better when I did my first big build (1991) I started with a pretty mint 86' GT and stripped it right down to the chassis. Then put it all back together with a cage, big brakes, decent suspension, built up rear end, the then hot shit Tremec trans (can't remember the #), bla, bla, bla.
First time the motor went in the machine shop had balanced it wrong. It came out.
Second time the motor went in the machine shop balanced it wrong.....again.
Third time the motor went in the new machine shop had suggested a different cam. And didn't tell me I needed to use a bronze distributor gear. It ate the distributor gear in about 10min. Had to pull it again and clean the crap out and replace the bearings.
Fourth time it went in it ran for a few drives. Then I hit it with a 150 shot and split the block open.
The fifth time was a charm! Ran it for three seasons doing a ton of street racing (I would go through two tanks of Turbo Blue/night street racing). 12.5:1 347 that spun to 7,500rpm and eventually ended up with a 250 shot on it.
Keep pluggin away. It will work out.
AutoXRacer
Florida
I guess this is pretty common... sigh
Whatever happened to getting it right the first time???
Is that no longer a thing?
I see it on those TV shows where shops send out a motor to be rebuilt, fire it up, and have to send it back. Actually, it happens on all the shows except Overhaul... lol
I'm on my 2nd try...hoping the 2nd is a charm.
crownaviation
Broke dafuk down
Jumped time.. damn. How did the timing chain and guides look? They all fucked up too.. causing this? That sucks a dick for sure
