Chasing Superchager Belt Issues/Engine Knock/Clutch problems
GT500KR
Quad Cities, IA
Pulled both heads. Driver side is good. New phaser on passenger side broke. Spring and timing fingers fell off when I removed the bolt. Pin snapped and that's what trashed the valves and pistons.
Fuck!
Driver side
Passenger side
and of course my signature picture...
crownaviation
http://www.tudyno.com/
Broke dafuk down
Gonna TIG these Fucking phasers onto the new cams. Fuck this ford engineering bullshit.
The cam pin likely failed when the pistons contacted the valves. That is a shit load of bind on them.
How were your chains and guides? Looks like the Phaser failed creating your demise. Did you use genuine Ford replacement parts or the shit from Autozone? I only use genuine ford as aftermarket stuff is out there that is sub-standard to say the least. I know another guy that used autozone shit and his failed in little time also.
Are your pistons stock size? How do the skirts and cylinders look?
I have some valves but they are at Fox Lake right now. They are sending me my stock valves back when they are done in about a week. You need to replace the ones that made contact as they are likely bent. You should also inspect the valve guides or consider having some new ones put in (cheap if you have someone local to do them.. or have press setup to do them yourself).
GT500KR
Quad Cities, IA
Pretty sure the phaser failed which led to valve to piston issue. Regardless I think I'm gonna weld the phasers to the new cams.
Haven't pulled pistons.
Passenger side getting all new valves no matter what.
The don't physically look bent.
Phaser was genuine ford. Came from that place you guys recommend that came with a wedge too.
Pistons are .020
Chains and guides are perfect
blownGTvert
Zeeland, MI
I feel your pain bud! You've had more than your share of bad luck! Stick with it, you will get it sorted out.
Scott
King City, Ontario, Canada
Pistons are .020
Just for fun, did you pour some liquid into the combustion chambers to see if it leaks by the valve seats. If it does they are of course clearly bent even though you can't see it.
GT500KR
Quad Cities, IA
Lol no didn't think of that...
They hit the pistons... they are getting replaced even if they aren't bent. Not taking chances. Get it running...tuned...sold
Sent from my SM-N900V using Tapatalk
GT500KR
Quad Cities, IA
not officially giving up. but once fixed what do you guys think my car is worth?
2008 Mustang GT premium
70k on chassis
K FRPP springs
20x9 saleen wheels
new tires
stock trans
spec stage 3 clutch
5.0 stroke/bore
manley billet i beams
kellogg crank
manley billet/forged pistons
comp cams
DOB blower
innovators west 10% od balancer
kenwood deck( all new kenwood speakers)
Fully ARP studded motor
ported heads
BBK cermaic equal
thanks
70k on chassis
K FRPP springs
20x9 saleen wheels
new tires
stock trans
spec stage 3 clutch
5.0 stroke/bore
kellogg crank
comp cams
DOB blower
ported heads
BBK cermaic equal
thanks
If you happen to wreck it, total it, buy it back and part it out then you could get $30K-35K out of it. :thumb2:
GT500KR
Quad Cities, IA
I try to find info and youtube videos of the 127450 cams you guys recommended. .. but I can't find nothing really. I see alot for the 550 cams...?
GT500KR
Quad Cities, IA
There is only like one or two videos on Youtube about the 450s.
Yea I saw. That's what I'm saying... :/ oh well I called comp cam and another vendor and they both backed you guys up with buying the 450s
GT500KR
Quad Cities, IA
finally got all my parts in. took forever. hard to believe the most modified car platform seems to be the hardest to get parts for :/
GT500KR
Quad Cities, IA
Got the motor back yesterday. Had it back in the car in under 3 hours.
FYI install headers onto motor before going into the engine bay still sucks. Couldn't fathom putting them in the car.
Don't have a current pic but it's all together minus the mid pipe and priming engine oil. And front bumper etc
