And here I am with no issues. TR-6060, RST, McLeod steel 6 bolt flywheel, 4.6, Ford slave from Ford dealer.
Well its things like this that make me think its an issue witht he clutch itself.
Jeremy,
Is there any chance the wrong pp was used? Do you know what part number was installed? It's written right on the pp.
Hey I just thought of this. You don't by chance have a black ring that bolts up to the flywheel do you???? When I orded my last clutch rxt it came with a black ring that bolted up to the flywheel. It pyshcially bolted up by I knew something was wrong when compaired to the gold ring/rst. I called up Mcloed and they said the black ring was for a 99-04 cobra and I could just unbolt my black ring from the PP and reuse my Gold ring. Check that out it might be a problem there. Also a note that it was smaller in diameter than the gold ring.. Worth checking out.
This thread is the reason I won't being swapping to a TR6060.... I'll gladly wait for the T56 Magnum. If it doesn't come out, time to upgrade the 3650!
Waiting on the T56 M will not save you any problems, as they use the same parts, the only thing the T56M will give you is a fixed shifter, instead of the remote, and a better sync rings, and the mid plate is not built into the bell housing.
I want all of those things... LoL I'd really like to have a nice bell housing so I don't have to use a diaper. Exploding clutches scare the shit out of me.
Edit: Also, by waiting I give you guys time to solve all this crap.![]()
The pp fingers have nothing written on them on mine....
well im just curious of the difference between the part numbers and why lethal has 6913 as a part number but every where else i look has 6912???
