jodadejss06gt
TEAM DELETE SHIT
Is Mike putting the new slave in for you? That really sucks man! I hope that doesn't happen when I get your old clutch put in mine.
Yea def. not doing my own clutch work lol.
play that video and close your eyes.
Does Autozone have a rental tool for that?Did you check airgap ?
No not next to the muffler bearing grease, that's where all the expensive stuff is at.No rental but you can buy 1, its kept next to the muffler bearing grease
Ok so here are my thoughts. Jeremy I sent the clutch slave that you took off your trans to Steve Poe. When he got it he said its about 3 inches shorter than the one that came out of his trans and that in 10 they changed the system on the gt500's. I'm having the feeling you somehow got the incorrect clutch slave when Mike put it in at MAP and being the wrong one it never would bleed correctly somehow. Does this make sense? If you ordered another slave that was the same as the other one, it may mess that one up too????
The '10 and up slaves must have a longer throw. The clutch TSB's for the '07-09 GT500's have you upgrade to the '10 style slave cylinder along with a new clutch line. This tells me that they're all interchangable, but the '10 slave must have a longer throw which would help disengage the clutch better.
