Yeah thats the one I used and had trouble with.
Damn man this is a mess, I hope you get it worked out because I'm not sending your RST back![]()
I agree, I miss the days of the clutch cable and quadrant adjuster.
Man its probably a good thing I tried to send that shorter slave off to Poe otherwise this info would have slipped right through the cracks. Thanks for the pics^^^^
For sure!
It still would have worked though, they are interchangeable the shorter one is just a newer design. They arent 6060 specific its also used in the 2010 with the 3650.
93cobra, let me see if i understand how these work. The slaves rest on the pressure plate fingers and is compressed when installed, then when you push in the clutch the fluid fills the cylinder and pushes the outside back out on to the pressure plate which disengages the clutch. So it seems because the earlier design is longer it would have more load/or clamping force which could sometimes keep the clutch from fully disengaging. ?
