Duce714
I have an 06 GT that I picked up used, I was told that it had been stroked, has hot rod cams and long tube haeders, x pipe And full aftermarket exhaust out the back. Sounds great! My question is for someone with the hot rod cams. When sitting at idle with the A/C on and in neutral with foot off of the clutch, the clutch makes a shaking/rattle sound. Push in on clutch and the rattle is gone. With A/C off in same configuration, there is no rattle. I was told it is because with A/C on RPMs drop slightly at idle causing the engine to shake more causing the clutch rattle. Nature of the beast I guess. Could the idle be bumped up slightly to correct this and if so would I loose the lope of the cams?
