Morereps
- Joined
- Jun 27, 2017
- Posts
- 8
- Reaction score
- 2
If this isn’t correct, could you email me the the correct way to achieve this? I would greatly appreciate it. My email is [email protected]. I can pay you if you would like payment for your knowledge.
Ok cool!!! Now I just have to find ignition switched voltage in the engine bay.....lol Thanks again sir.everything is right except the circled blue should be ignition switched voltage and this should be your small gauge wire side and obviously that load side(large gauge wire) marked fuel pump, should be to one side of your fan resistor. Hi or lo. 2 relays should be wired in, one for lo one for hi and ecm activates one of these circuits for a/c also so no need to go digging there
I know it's been a while since this forum has had any activity, but I have a question regarding the ignition voltage. How much does it have to be exactly? Is 12V enough? Also, will air conditioning work directly with this wiring or do I have to add an extra circuit? Because I hooked up the relays externally to check if the fans worked, they did but the AC compressor wouldn't trigger. However I still have to connect the fans in this way. I am just asking so that I can buy any extra necessary things.everything is right except the circled blue should be ignition switched voltage and this should be your small gauge wire side and obviously that load side(large gauge wire) marked fuel pump, should be to one side of your fan resistor. Hi or lo. 2 relays should be wired in, one for lo one for hi and ecm activates one of these circuits for a/c also so no need to go digging there
I bought the new upgraded cooling fan resistor from the dealership that runs cooler that the ceramic previous design that got too hot and drew too much current overheating the wires and melting connections. However, I want to fix this problem permanently by adding 2 external relays. Sooo...On the back side of that connector, there is a 12 gauge green/violet wire. You need to cut and connect to a 40 amp relay. Run 10 gauge from your battery with a 40 amp fuse to your relay. Then cut and use the wire that comes from the computer that normally triggers the factory relay to trigger your new relay, I believe it is a smaller green/violet wire.
http://iihs.net/fsm/?dir=40&viewfile=Cooling Fan.pdf
This is what I'm having trouble with I wired the relays all I need to wire up is the hot on run 12v power supply, any help/pics of the wire you used for this pleaseOk cool!!! Now I just have to find ignition switched voltage in the engine bay.....lol Thanks again sir.
