Decision On Cams
HellsBells
620/677
SoCal
bbr sounds really good and like i said i bet they make the most power
And I'll bet they don't! :roflmao:
I don't care bout drivability that much... I want a nasty sound with good power
You should try driving a car with a real aggressive cam profile. The real bad ones are a total pain to drive if you have a manual. I once drove a car where you had to basically slip the clutch until 3000RPM and then you could let go completely, otherwise, it would buck and the car would leap forward and back. Kinda like when someone doesn't know how to drive a manual so not only can you not drive the car properly, but everyone around you thinks you're an idiot.
Newman
sumidicsayhuh?
Houston
pm steve or if you want ill send him a txt message lol
just cut out the middle man call liz steve john chris any of them there will help you out
tell them dillon dollar sent you
Steve responded to me once about a month ago ... I know john has been out but i sent him to messages in the past 5 days or so
Newman
sumidicsayhuh?
Houston
Ive driven a 02 SS with a big cam and i liked it . But that might be a completly dif feel than or cars ..
HellsBells
620/677
SoCal
All I'm saying is, don't get a mod that you'll love at first and then start to hate. If you're not going all out on a crazy track beast, why make life hard on yourself? All the cams you mentioned are just about the same thing, in the same price range, with the same gains, and similar qualities. It's a toss-up really. I partially went with the Hot Rods also because it's a Ford Product--not that it matters, but it makes me happy that way. It's cheaper than the other two, it's tried-and-true, and you have people with very little mods running them (like me) and you have guys with 500hp cars running the very same hot rod cams. Sounds like a winner to me, but as are the other two options.
If you're looking for a new email tune with it, I cannot recommend AmericanMuscle enough for the Hot Rods. Mine fired right up and never had a problem with it.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
FRPP Snotrods!!!!!! FTW!!!
Dillon Dollar
oklahoma
Iv hot a 100 dollars that days they do... It will go Bbr stg 1 then Detroit rocker then hot rod
Dillon Dollar
oklahoma
Shoot me a pm and ill get you hooked up you really can't go wring with the Bbr stage 1's
HellsBells
620/677
SoCal
Your right no one can unless a direct comparison is done, but i still stand behind my claim that the Bbr stage 1 is a better cam
So, you're conceding that you can't prove your claim, but you'll continue to endorse it--despite knowing it may very well not be true?
stang72
Family of Stangs
tennessee
This is my take on it.If BBR does your tuning go with BBR cams,if AM go with hot rods,if brenspeed then detroit rockers.If dyno tuning just get which ever one you can get for the cheapest price.I'll bet unless you are F/I or have ported heads they'll be within 5hp of one another.
Newman
sumidicsayhuh?
Houston
^^im open to whoever for tuning if its gonna be up to oar with BBR
Dillon Dollar
oklahoma
Well i kmow fot a fact that Bbr stage 1 is better than a hot rod since i have had both cams in my car and the Bbr made almost 10. HP over the hot rod...only variable is the Detroit rocker and I doubt its better
Kadorja
FNG
Jax, FL
It all depends on what you're looking for. Each cam sounds a little different. I'm a fan of big lopey cams but I've heard some cars that sound like crap because they have excessive cam lope. Now my Harley would sound awesome with a retarded cam in it because that's the way I want it to sound and it has drag pipes.
I personally searched a lot and decided that since I wanted NSR cams I would get FRPP Hot Rods. I had a good deal from AM.com at the time so I got them. It's an extremely noticeable difference from stock and I will say the Hot Rods add power mostly after 3k rpm. If you're going for all out power then picking a NSR cams isn't the best choice anyways.
Given the money I had at the time and what I was looking for I was extremely pleased with my Hot Rods. I am currently at 380hp and still need to install my UDPs. I'm actually kind of worried since I want to be at 450rwhp when I eventually get my Saleen Supershaker and I think I will be closer to 500rwhp if I don't detune it. Maybe that means I could go back to 87 octane again :)
Dillon Dollar
oklahoma
may i ask what mods you have to make 380 hp???
HellsBells
620/677
SoCal
"almost 10 HP" is completely negligible. You can attribute that to so many factors that it's not even a measurable actual gain.
SteveP
Modular Specialist
Boynton Beach, FL
We can tune for all cams. No issues what so ever. Bama can as well.
SteveP
Modular Specialist
Boynton Beach, FL
BBR Stage 2 cams VSR Specs
Gross Lift Intake- .492, Exhaust- .492
Advertised Duration Intake- 284°, Exhaust- 294°
RPM Range 2000-6500. 241/251 .050"
BBR Stage 1 cam NSR Specs
Gross Lift Intake- .480, Exhaust- .480
Advertised Duration Intake- 270, Exhaust- 276RPM Range 1500-6000.
FRPP Hot Rods Cam Specs
Duration at .050", intake 221, exhaust 240 ,
lobe separation 110 degrees
You can see the difference from the FRPP and our stage 1's.
3VPOWA
East Texas
Jesus with the pissing match in here. Just shut the fuck up. :deadhorse2:
OP, just pick one. You stated that you're going more for sound than anything, so don't worry yourself about "which one makes the most power" between those three. They're all pretty similar in that regard, and you can't really go wrong either way for an NSR cam.
