Dirt cheap Coyote cams
19COBRA93
Ford Racing
Clinton, Ut
Psst, over here........http://www.tascaparts.com/ford-raci...ation/m-6550-m50gte/?search_str=m-6550-m50gte
I do not know how many set FRPP has left though.
-Steve
These are two different part numbers of cams, and are priced differently. Just so you guys know. Depending on whether you want more lift, or more duration, determines which cam set you will want.
wbt
I prefer more duration and would choose the lower lift "CJ" cams personally.
SStang
SOB, wish I knew that before buying them. I would of bought them from you. Sorry.
SStang.
Steve@Tasca
SStang.
No worries, I can't sell everything to everyone. :)
But to install them on my Coyote, I need to modify the heads, correct?
Not necessarily, this is direct from the FRPP tech notes on those cams.
" Check cam follower roller to cylinder head clearance with base 2011- 2014 Mustang GT 5.0L 4V Ti-VCT cylinder head"
So apparently there's enough variance in the head castings that some may need work and some may not, it's pretty much a case by case basis.
-Steve
Gremlin85
MA
-Steve
And me in my driveway probably can't do it if it needs it?
GrabberBlue5.0
Gold Member
Louisville, KY
I understand what duration and lift are but I don't know what one is versus the other, why would you want more of one versus the other?
To be a little more clear, why would I want cams with a longer duration over a higher lift or vice versa?
