Need to post a WTB in our vendors section to get a good price!
LOL..
LOL..
The GT500 TB is what I installed on my 05 Gt stock manifold. No spacer needed and the 60mm butterflies clear the manifold opening with no problem. You will need to spend about 20-30 minutes elongating the mounting holes (with a rat tail file) about 3/16" to eliminate the need for a spacer.
The opening for the GT500 TB is a larger 5" compared to the 4.5" stock size. For some CAIs this may cause a fitment problem. My K&N coupler would not fit and I had to fabricate something. A few weeks later I installed a JLT and that coupler fit with a little elbow grease.
CJ Pony Parts has the GT500 TB for $129 (free shipping) but they run it on sale for $119 from time to time. http://www.cjponyparts.com/product.asp?pn=TB100
You can see the difference in the size of the TB mouths the GT500 is 5" dia and the stock TB is 4.5" dia.
Personally I would stay away from the BBK unit. If you take them apart and compare the BBK to the FRPP piece you will notice that the BBK units gearing is plastic compared to the FRPPs metal gearing. Dont get me wrong the plastic intake we have is great, but plastic shouldnt be in moving parts. Just my two cents.
i guess what my actual question is, should i look to accufab, c&l, etc for a specific gt aftermarket throttle body because it has better gains than the oem gt500 or that they are so comparable in gains that its a crapshoot, save the extra coin and go gt500Anything that will allow your forced induction engine to breathe more and breathe easier will net more power. Are there better options than a GT500 TB? Yes, are they more expensive? Yes. Will you make more power with a GT500 TB? Yes.
Had to reread the entire post. For someone reason I had thought he was talking about the FRPP TB which has metal gears, didnt realize he meant the GT500 TB, in retrospect obvious if I had read the title. Sorry for the confusion.I thought the GT 500 TB has plastic gears as well...I can check my stock TB.
So my question is since you used the larger TB, but with the stock manifold, did you see any gains? What were they? Did you have the car tuned for the new TB?
GT500 TB came in and I elongated the mounting holes to fit the FRPP intake manifold, opened the butterflies and to my amazement the TB is to big for the manifold. I guess an adaptor is needed. Oh well.
I don't have the mounting bolts torqued all the way because the butterflies are making contact, besides it looks like the lip of the intake could create some turbulence.From my understanding the only reason you need the spacer is because the blades can't open all of the way. It looks like you have the blades open all of the way.
FWIW, a GT500 TB won't fit the FRPP intake without the spacer. The blades hit (barely) and the o-ring seal isn't even close to being in the right place. I'll post some pics in the morning.
ohhh crap... hahah I forgot all about that.. I did the gt500 pump and now have idle issue.. but I forgot that I also took off that spacer.. I thoht the holes wouldnt line up without filing the thing.. but it did and I put it on.. hahah.. I caused my car to go lean.. ha ha ha... I'm a dumb ass =-/
Intake and gt500 tb my next mod
Push open the blades of the throttle body and you'll see the whole gasket exposed on both the outside edges on the intake. It's not going to seal (as you found out).
it took me 20 minutes to put the t-bolt clamp on the TB!.. there was no extra slack.. I had to form fit the thing with my hands while pushing both sides together and then some how put the nut on... cant they make parts more user friendly.. haha
