FRPP intake manifold...is this normal?
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
Just received a voicemail from FRPP; the company line is that this is "normal" and called "tincanning". They said that the 2000 Cobra R manifold did it too. I still don't like it.
I Googled the term "tincanning" and found one definition, "A slight buckling in sheet metal, causing a wavy or uneven appearance." Yup, sounds normal to me. I mean, who wouldn't want their intake manifold to do that?? I want my fuel injectors to pivot and move too while drag racing or road racing. Seriously, WTF? :tdown:
bullitt boy
NJ
The small amount of movement in the injectors is at the bottom, not the top. You guys are getting your panties in a bunch over nothing.
Can you please explain to me how the bottom of an injector can move if the top does not? My point is that logic would dictate that a tubular solid mass [injector] when being moved at the top [by the flexing] will move at the bottom as well and the middle for that matter.
In the OPs vid the whole fuel rail is moving outward and inward at least 1/8 of an inch. Ford can call it whatever they want to ..tincanning,balloning,swelling,restperation .I call it not mine at this point.
GrnBullitt08
Dale Jr
Northwest Indiana
Really raises concerns for me, I looking into adding a FRPP manifold here soon when I do my gears. I might be better off going C&L.....maybe. I havent heard any complaints as far as performance, and for the price its hard to beat.
bullitt boy
NJ
I am going to wait this one out. Down the road I can always get either one ,I want to see what the outcome of this development is going to be, before jumping in a new direction.
I always liked the look of the C&L but the weight of it and it possibly holding heat always put me off it.
19COBRA93
Ford Racing
Clinton, Ut
Because the injector moves with the fuel rail. There is no movement between the top of the injector and the fuel rail. As the rail moves the injector moves with it pivoting at the bottom. Does that make sense?
bullitt boy
NJ
I understand that but the whole fuel rail is moving hence the top of the injector is moving with it. Just went out and started my car [stock intake] had my son rev the piss out of it there was zero fuel rail / injector movement. Woke up the dogs and pissed off the neighbors.
zxmarekxz
NE IL
I remember old threads that the CL power gains vanished once it heated up. I believe that was with the redesigned one, and the first version just straight up sucked. still, I guess it would work out with boost. It's been a while since I researched this though. Do they actually make power now, maybe with boost?
bullitt boy
NJ
I always was under the impression that any gains would be stolen by the heat as well, even with boost the car will still pull timing when hot.
lostsoul
2014 vett or 2015 stang..
Gay Area
crap.. looks like I will have to install mine tomorrow and see... how long is the install?
whats the steps? do I put oil on those green gasket rings? I have deletes in the tune so I should not throw any codes... but it is confirmed that I can drive with this safely without tuning for it(under 5k)??
US-1
Banned
The ShadowLands
No it didn't.
Hmmm, "tincanning". Interesting, I thought the Cobra R intake was aluminum?
It was. Very stout too. No flexing.
If you would actually read all the posts you would notice that someone called the FRPP hotline and FRPP said that is NORMAL, its called Tincanning.
Yeah...a glorified parts counterman told him this was normal. You do realize the engineers won't get anywhere near a phone don't you?
Twinscrewgt said:
Nice try, again, you make yourself look stupid:thumb:
Look into a mirror and repeat statement, you condescending jackass. Take your ass to VatoZone and believe everything they tell you as well.
Nope. Didn't happen on the three different combos we tested it on. Depends on how good your tuner is.
Twinscrewgt
Bad Smurf
Ogden, Utah
Please show me where I stated an engineer answered the phone?
You must be one of those ass hats who think they know everything about everything. You probably call Microsoft tech support and tell them how to do there job huh.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Ruh roh! I think there's gonna be some bloodshed soon.
I'm going for wings! Somebody grab the beer!!!
I will say this much, you gotta give credit where credit is due and SD(US-1) called this from the "get-go". He said there would be issues with a plastic intake from the initial release of the plastic lung.
zxmarekxz
NE IL
No it didn't.
Interesting, if thats the case, it may end up under my hood one day...
