Go Big or GO HOME !
just the pump for one. you need hose , y, clamp, and some connectors to add a second pump, i have 2 walboros on my stock hat
TurboPete
Miami, Fl
looks good! whats the flow rating on those suckers? lol
Its a 340 lph pump , at 40 psi's its 340 lph , at 70psi's it flows 265 lph, while the Walbro flows about 210 lph.
The best difference is that its E85 compatible, and that while the Walbro falls off the charts at 80 and 90 psi's these pumps still flow over 200 lph at 90 psi's .
Pete
07 s197
hampton, va
Two pumps would be overkill on a N/A car , also these pumps are for a return style fuel system . Not sure if it will work on returnless.
Pete
Its says on their site they can be used in pulse modulated systems. So I guess we need someone to try them out
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
Im down I just got that 76mm kit and wanna get a better fuel system than what it's coming with. So the pumps some hose... Anyone wanna hook me up with links this is my first swing at this kinda stuff don't wanna mess anything up. But will order what I need and be the guinea pig!
TurboPete
Miami, Fl
Go to Lethal Performance / Fore Precision they have everything you will need.
Pete
TurboPete
Miami, Fl
Took the car out for a quick spin , jumped on the highway turned the boost controller up higher then ever which gave me 21.9 in second gear and I lifted in 3rd before it really started to get into load.
The a/f was 10.2 so these pumps flow alot of fuel. Will need to retune, but will wait for the Big Turbo !
Im very anxious now that I see I have more room with fuel .
Pete
why? it si a blast to run more then that. just make sure you have room and good brakes.
Because it's stupid and reckless, and its the street, to many chances for something to go wrong. I do have really good brakes and 12psi/550rwhp is more than i could ever want or use on the street.
Actually im pushing it already on street tires.
Oh i know fun and enjoy the shit out of my car, what you descirbe is not appealing or fun to me.
