Well as the saying goes , its time for a little change on my set up .
Here's whats going down, my Walbro Pumps are beginning to act up. I have been on E85 for awhile now, and as it was, I was pretty much maxing out the pumps with my set up, and stuck at 22 psi's . Since the Walbro's pretty much start to fall off at 72 psi's I was right at the limit running 50 base pressure . I want to turn up the boost to 27 or 30 but cant do it with these pumps , so I have a new game plan and in the next two months I should be able to get it all worked out .
First Im re-doing the fuel system with a Fuel Lab 1300hp Prodigy Pump and filters.
2nd Im taking the ID 1000's out and replacing them with ID 1600's .
The last piece of the set up is a New Turbo and 4" Downpipe .
I'll be ordering the Turbo in two weeks GTX 4202R Garrett.
Still stock heads and cams but with this Turbo and 27 psi's I think low 9.s are in reach.
I will update the build as I go along and post pics and results .
Pete
Pete
