Interesting stuff, the mafia actually reduces maf output voltage to prevent it from pegging and in turn reduces the pcm fuel and load calculations . So everytime the sotck maf reaches 5v, changing the mafia setting reduces voltage signal again and so on allowing you to make more and more power on the stock(5V) sensor.
So effectively the hpx maf(12v max) allows for over twice the adjustability with the mafia over the stock 5v maf.
If the 5v maf with mafia pegs around 800-900hp
The 12v hpx (2.4 times max voltage than stock) would be able to make 2.4 (12V / 5V = 2.4) times the power with the mafia for around 1900-2000 hp, (800 X 2.4 = 1920), makes sense to me now.
Read all the posts again so you can think again on your "recommendations".
I'll give you the facts so you can redo your math.
There are two limiting factors:
1) The PCM won't allow a MAF input signal greater than 5V, that is when the MAFia comes to the rescue, it translates the actual bigger voltage output of a MAF signal into a 0-5V range the PCM will then read complete.
2) The stock sensor won't work well over 5.5V, some will go to 6V, so you should not use them with MAFia settings bigger than "2", "3" on some.
Given the previous facts, you just cannot keep switching the MAFia, because it just won't work.
Other facts:
1) The HPX has close to double the range of the stock sensor, it is not that it will only allow more voltage output, so you will achieve the same range with half of the pipe section.
2) Bigger pipes generate more turbulence and the pipe you will need with a MAFia and a stock sensor to hold 800+rwhp (without doing some calc I guess it would be 4" at least -maybe more-with MAFia@ 3) is just almost impossible to have a worth signal inside on a blow thru config.
3) You can make 800+ on a 3.5 HPX without any MAFia (BTDT), the problem is how to accomodate a long and straight enough section of 3.5 pipe under the hood.
So, realistically, it is too hard to make over 800 on a blow thru config with the stock sensor.
One other thing, there is no need to adjust injector slopes or displacement (per MAFia's manual), just need to see the MAF as a new thing with a completely new transfer function and everything will still makes sense automatically, load will be right.
