VanWilder
Well after doing my datalog from 2000-6500 in 4th gear at WOT we noticed at the spot in my dyno that the dip occured not only is my clutch slipping but I'm pulling about 3 degrees of timing. We are completely baffled as to why...Chris sent me a new tune to try tonight that may or may not fix it...we shall see but he said I could be having spark plug blowout which could be caused by my coils starting to go out so I wanted to know how to check each one to either rule it out or find a problem...also it could be pulling timing because the clutch is slipping and causing the load to change thus making the engine pull timing...he tweaked the tune so that if this is the case it wont happen again...hopefully it fixes it but I wanna get a jump start on if it doesnt
Thanks,
-Lance
Thanks,
-Lance
