ulev1st
Mustang Addict!
Start..stock 2006 Stage2 Roush.
Added this winter:
COMPLETE rear suspension by CHE and BMR w double adj QA1's
4:10 FMS gears
Alum Driveshaft with loop
MGW shifter
Ram Dual disc clutch
BBK long tubes and x pipe with Roush mufflers.
BMR component subframes
BMR front K member with CHE brace
TEA CNC ported heads that flow 281I 207E at full lift of cams
Comp XE261H-16.5 Cams and springs
BBR cam VCT lock out plates cams set @114 deg lock
Whipple 2.3 wi GI Joe 8 rib kit and 3.00 blower pulley
ST Motorsports custom blower inlet (Adams finest work yet!)
ST Motorsports Custom CAI for same.
Mafia extender
Stock mass air
Black Diamond Wide oval Throttle body
Edge 60 psi injectors
Eagle/Diamond stroker kit 298 CU IN
MMR cryo oil pump and pickup
New ford cam tensioners and guides
Probe lower girdle
Mezeire elec water pump
Brisk plugs
CPR Fuel rails
ZEX wet kit
Canton catch can, rad exp tank, blower exp tank and PS reservoir
Twin GT 500 pumps
Added this winter:
4:10 FMS gears
MGW shifter
Mafia extender
Stock mass air
Probe lower girdle
Brisk plugs
CPR Fuel rails
ZEX wet kit
Twin GT 500 pumps
