DieHarder
- Joined
- Nov 9, 2019
- Posts
- 1,851
- Reaction score
- 1,073
Looks good! The only other areas if you haven't already done so are the vertical surfaces. I noticed a significant reduction of noise once I did the walls in the back seats and into the trunk. I also did the outer tub surfaces just behind the front wheels (install it to the vertical tub surfaces; have to remove tires and plastic covers from the wheel wells) which cut down road noise as well if you have enough material. I would avoid putting it on the inner walls of any outer body surfaces in the trunk in case you ever get a small ding. Removing this stuff is a bitch for something simple like a paintless dent repair.
The only other area I've been thinking about doing is the interior of the roof but just haven't got around to it and I need to buy another roll before I can do anything.
If you're satisfied I'd say put it back together, take a ride and let us know what you think.
Also the spare was used enough that the tread is worn down and it was flat.
