jodadejss06gt
TEAM DELETE SHIT
Thanks Charlie. The wideband just came in yesterday. I had to pick up another firewire cable and I extended all the lines on the LC-2 today to make their connections. I've got a 10 pole fuse box with cover coming tomorrow to finally clean up some wiring under my dash. I will be running a dedicated wire off the battery to a relay and then to power this unit. The relay will be powered by a 12V ACC add a fuse.
I'm going to reprogram the 2nd output wire from the LC-2 to be the same as the 1st. 1 will run to the gauge while the other runs to the firewire for data logging. I'm also going to hook the wiring up with a USB extension cable on both ends so that the fire wire cable will just plug in and not have to stay in the car coiled under the dash.
http://www.amazon.com/dp/B004S2YCE6/ref=pe_385040_127541860_TE_dp_1
