Marc s
NASA AIX
Very cool!
Thats much better... what PSI did it end up putting out? 6 or closer to 10?
I'm running 11psi, not sure of the WOT (I'll check the with tuner). The amount lower end torque is great to have. Looking into going to firebird raceway here in Idaho this summer to due a couple of runs and/or the Bonneville salt flats (about 4 hours away from Boise).
..my questions are along the same lines, as I'm seeing higher power levels with a 3.5 pulley, larger TB, and automatic trans. With little/safe timing (around 8*), I was seeing 430 or so at the wheels.
We installed a KB 6.2 stage II on my Son's 2005 Mustang GT and got 440 HP @10psi with 19 degrees of timing with the A/F at 11.5. I would also be interested to know your setup?
Your running aftermarket headers with the stock KB tune? Their instructions say that's a no-no.
The secret (so I have been told) to power in the 3V motors when tuning the VCT is knowing how to dial in the cam timing. @ 19 degrees of timing I would expect 500 rwhp. I'm at 17.5 running 475 with a 10 psi pulley.
A little experimentation with the cam timing will generally result in the same peak rwtq, but it flattens out a little bit more and you get some more HP.
It also kind of depends what RPM you went up to. Some guys have the same exact tune but one stops at 6000 and the other go up to 6800. Makes a difference.
Did you get a pulley with it madmax? Stage 2 according to their documentation uses the same pulley as the Stage 1. Only difference is the throttle body and the tune.
Not sure what he did on the cam timing, but I think he set the rev limiter at 6,200 or 6,800 (I asked him to go conserative on this, it is my 19 year old Son you know). I will check with him and I need to get the dyno chart from my Tuner and post it. These numbers are from a dynojet 224 dyno, what type on dyno did your numbers come from? I hate running 2 more degrees of timing and putting down less HP from the car. Keep in mind the car has a 4:10 gear and we are using a dynojet. Not sure, but we may need to figure out what is holding the car down to 440 rwhp with 2 more degrees of timing. Are you using the KB tune or did you also have your's dyno tuned?
It is what ever the kit came with for the SC, but it does hit 10 lbs of boost, we had a boost guage on it on the dyno and I saw it go to 10psi
