Lightweight brake options.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
What brake options are really out there.
I wan't to be able to stop good as the car is a daily driver, and will be pulling over 140 in the 1/4.
At this point though, i'm looking for anywhere to pull weight out of this hunk of metal.
no front factory Brembos on "blue blaze"?
mazroth
Someone mentioned to me GiroDisc, but thus far, I havnt had any luck with finding any for the 2011. Havnt tried calling yet, ive just been shopping around for weight savings.
wazslow
them are heavier, no chance of that
Not to mention you cant order them on an automatic car anyway.
Make sure you dont get anything with a thin disk setup. I had aerospace on my race car and they would warp like crazy from the street driving and heat. Good for 1 stop at the end of the track and then cool down time. Not real good for stop and go driving (although I did it anyway).
Not if you get 2pc front rotors.
Modshack
Greenville NC
Look at Wilwood if you want weight savings. I saved 11lbs per corner going to Wilwood Aluminum 4 pistons/2 piece rotors over a set of single piston Cast calipers on an Audi TT (similar in size and construction to the stock Mustang brake set). And that included going up from 12" to 13" on the rotors..
95ragtop
Fayetteville, NC
What about 05-09 brakes with DBA 5000 (2 piece rotors)? Not the best option but lighter and I'm sure you can find some easily.
wbt
Baer makes a kit that is very streetable and very reasonable.
corruptor
Also check out Vorshlag's auto-x build - he mentions some lightweight brake rotor options that work with the stock calipers for his auto-x project. Might want to PM that guy to see what he was able to cobble together.
Cars12369
Baer extreme kit 2450 shipped new PM me retails over 3k best baer kit out 6 piston
force recon
I have ran strange drag brakes on the front For two years on the street with no problem.
Clipboard
Willwood Carbon Ceramic Brakes
Only $7100!
This is as light as non drag brakes will get, by a long shot. I think the are 9lbs/corner lighter than "regular" brakes.
http://www.wilwood.com/brakekits/Br...WCCB Carbon-Ceramic Big Brake Front Brake Kit
I think for a drag/street car I would go with something like the Aerospace brakes and run cooling ducts. Then replace rotors as needed.
http://shop.aerospacecomponents.com/4pistonfrontprostreetkit07-10mustang-2.aspx
aerospace is the only one i found that offers a good setup for our cars thats not labeled "drag use only"
Kris302
My buddy Tommy uses Strange engenering brakes on his grand national. 11.5" ceramics. He traps 155+ and as far as i know has zero issues. But im not speaking from personal experience.
Sent from my HTC6435LVW using Tapatalk 2
