The Thermo-cool sleeve is for that other radiator tube that went along the front of the radiator out of the coolant overflow
Okay gotcha so the thermal cool stuff is the metallic heat wrap that wraps on the thin hose. Well i relocated my coolant tank so that hose doesnt run there anymore. I was thinking about using this themo wrap on the oil filter relocation rubber hose lines after i see how close the up pipe is to it.
Also im guesing the roll of heat wrap is for mainly for the up/down pipes.
