Long tube headers and clutch replacement...
Kylar
CT, USA
I tried searching, but got conflicting answers.
Can you drop the trans to do a clutch with long tubes? My searches have said No, Yes, And maybe depending on brand.
The Car is a 2005 GT 5 speed, the headers are boost brothers.
I'm running a DOB kit on the stock clutch, so far its holding, but i dont want to install the longtubes yet if i cant do a clutch with them installed.
Thanks for your input!
drive_55_not
I've got Borla LT's and it's not a problem to r&r the tranny.
IIRC those Boost Brothers headers are JBA clones so the transmission should clear them.
Getting to the top back starter bolt might be a beech with that one tube they bring down though.
As far as getting the top 2 bolts out, I string several extensions together [with a couple being the wobble type to get some angle in there] and go over the top of the transmission with a 13mm universal and stick my arm up in there and guide the socket onto the bolts.
Also, you'll want to use a cheap baster to pull the fluid out of the master cylinder to keep you from getting a full on brake fluid facial when you pop the line of the slave cylinder.
Kylar
CT, USA
Cool, thanks for the info. ill keep that in mind, def dont want a brake fluid facial...lol
ksack
If they are clones of the JBAs, you'll be fine. As far as the fluid in the face goes, my clutch kit came with a little plug to put on the clutch line. Remove it with a rag and get the plug in quickly and you'll be mess free!
saleen07gt
St. Petersburg, Fl
The trans cleared my MAC 1 3/4 long tubes but I ended up taking a die grinder to those 2 ears going back in, it went back in alot easier than it came out.
I just capped my clutch line with the cap that comes with the new slave. Works great sat for 3 months and only dripped a little. A vacuum plug etc would work as well.
Like said starter may be a pain to get out that about it.
ksack
Definitely take off the two tabs. I totally forgot about that but it makes a world of different
